0 members (),
194
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello!
Whoever had my '59 Apache before me saw fit to drill several holes in the lower lip of the rear wheel well. I have the bed off for new wood, de-rusting, painting, etc, and I'd like to patch these holes. I've successfully made and installed my own patch pieces, but these holes are pretty small, about 3/8", and they're in the lip area.
How should I fix them? The holes are pretty small, so holding a patch piece in place would be near impossible. I could hold a piece of metal behind the hole, weld it in, and fill the divot with bondo, or should I just patch it with bondo? I can get behind it, so I can keep the bondo to a minimum and seal it from behind.
Thoughts on this repair?
Thanks...
Chris | | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | If the hole is only 3/8" and the surrounding metal is good and can be accessed for cleaning to bare metal, I wood clamp a piece of copper behind it and plug weld it up gust like a fake spot weld. grind smooth no filler required, prime and paint.
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | i second that, it works well
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | You can mig weld copper to steel?
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | haha no that's the point. the copper is a removable back board for which to build the weld on till it fills the hole
| | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Ahhhh...I understand now!
You'll have to forgive a stupid question or two...I'm new at the whole bodywork thing, learning as I go.
Chris | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | no stupid questions...i only learned that brass trick thing 2 weeks ago!
| | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | One last question regarding the copper trick...how thick does the copper have to be? I have some sheet copper, but it's pretty thin stuff, maybe 18ga. Could I layer it by folding it over onto itself, or does the piece of copper have to be significantly thicker, i.e. 1/8" or more?
Thanks...
Chris | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | that I am not sure I have only seen it done with thick stuff.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Depends a bit on the holes but the low buck solution I used was pounding copper pipe flat on the end for a couple inches it comes out about 3/16" thick makes a great spoon/w handle and only costs a couple bucks.
| | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | I haven't used them yet but I picked up some copper backing plates from Eastwood that are made for this purpose. They even have built in magnets to hold them to the inside of whatever you're patching. They also have some curved spoons that they sell for surfaces that aren't flat. They are nice and thick. I don't think the thin sheets will work too well.
Steve | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I use plumbing parts too. Every so often they will clear some copper/plastic transition parts for larger pipes. I cut off the plastic and flatten the tube. They work out really well. | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Brad -
Great suggestion. I will give it a try.
Thanks...
Chris | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used this method to patch at least 20 holes im my firewall. I just used copper pipe flattened out and held it in place with a long set of needle nose pliers. I held the copper, my son welded, worked really well! | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | how big of a hole can you fill with this method?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well if you are trying to fill a large hole, a patch would be better. Welding is really creating a puddle and thus it doesn't produce a well controlled thickness like sheet steel. I had holes in the top of my cab from where lights had been mounted. This method allowed me to fill those holes. | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Update -
I took a 1/2" piece of copper pipe about a foot long, flattened 4 1/2" of it in a vice, then folded it over on itself 3 times in an "S" pattern so I had a piece of copper about 1 1/2" x 1" x 1/2" thick with a ready-made handle. Worked like a charm, all holes in the bed side are now filled and ground smoothe. cost for tool = $0. (ok, $.50 if you consider the scrap cost of the copper).
Chris
| | | | | Joined: Apr 2010 Posts: 18 New Guy | | New Guy Joined: Apr 2010 Posts: 18 | The sheet copper you have will work you can just fold it up. No bigger than your holes are. As long as you don't burn through the copper if that happens just fold more layers. | | |
