0 members (),
100
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 8 Apprentice | | Apprentice Joined: Feb 2007 Posts: 8 | I am having difficulty getting two large dents out of my 1955 2nd series truck roof. I can not access the back of the dents. I am fairly new to body work and would appreciate any and all advise on the proper method of getting this type of work done. Thanks, Brian | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah those are a bear if around the sides of the roof panel ... need to pull them, either by drilling and inserting some pull device or by welding a pin on to provide a pull ... in some locations you might need [or be able] to make a hole in the inner panel to push, then patch the inner hole .... approach depends on if there's actual creasing involved, which will make it tougher
Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You need a pin spotter-it spot-welds a small pin onto the metal, which you then pull using a slide hammer. | | | | | Joined: Feb 2007 Posts: 8 Apprentice | | Apprentice Joined: Feb 2007 Posts: 8 | Thanks for the reply Bill. Both dents are on the rear corners by the drip rail. One I might be able to get at underneath but the bigger one I will have to drill and approach it from the top. But at least you have provided me a starting point. Thanks,
Brian | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it is a simple dent, then you need to push on the middle of it and tap with a flat hammer around the edges. In this case, trying to pull out the middle will create new problems. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Thick, are you going to attempt this without the use of bondo, doing real metal straightening? If so, I would like to suggest getting a set of old school body hammers and dollies, an adjustable vixen file, making a "slapping file" out of a coarse tooth metal file and practice on some scraps with all of these tools.
The dents you are working with can definitely be repaired to perfection without bondo, but body metal is very thin and easily damaged. The slide hammer methods do a lot of damage that can be filled in with bondo if that is your intention. If you do not intend to use bondo, skillful bumping from the inside with a dolly and filing with the vixen to find the low spots then bumping from the inside with a pick hammer to bring up the remaining low spots will get 'er done.
You will be able to feel irregularaties in the contours with the palm of your hand if you place a thin piece of cloth between your hand and the metal and you will be able to see subtle irregularaties in the dim light of dawn and dusk.
Ray
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Yar, he said he can't access the back of the dents. I guess he could cut a hole in the inner panel, work out the outer dent, then weld the removed metal back in, but that sounds like it could easily end up a mess of it's own.
I have a couple of thin dollies that might fit in between the inner and outer panels....
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Brian, I've been there! Backed my 53 into my NEW 1 week old 5th wheel, denting the roof at the corner. Dent was as big as a soft ball! Mig welded a 3/8 nut on the center.2x4, 2ft long with a hole,3/8 inthe center. A peice of 3/8 althread rod about 1 ft long with a nut an washer. Then POP it out, might take a cuple of shots, but IT WORKED. Very littttttle bondo,came out like it never happened! ps the cornor of the camper just got a little paint on it, compounded out....Paul, let me know how you make out
| | | | | Joined: Feb 2007 Posts: 8 Apprentice | | Apprentice Joined: Feb 2007 Posts: 8 | Paul, The welding of the 3/8 nut worked on the top of the roof? If so I plan on trying that method because I cant reach the corner with any flat tools I have from underneath. Also, Do I work the nut and washer down to the 2x4, just a bit confused. Thanks, Brian | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Brian, TACK the nut on 1/2 way around, incert rod, 2x4, washer WITH nut on top end. With 2x4 ON the bottom of the rod pop it up to the top fast and sure. Might have to do it a cuple of times. Then bend to the tack side weld and it will snap off. If you got to do it in other places do it.Grind off tacks when your done. Cheeper then a stud gun (if you got a welder) and most user frendly..I got to tell ya, I was a welder over 40yrs. And I know its not beond the reach off anyone with 2 thumbs. Go for it, keep me posted, Paul | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Brian, I'll add a ps....You can try what we use to call a draw nut tech. which is welded nut, rod, nut, washer, THEN 2x4. Span each side with a wide base, enuff to bare the force of the 2x4 pulling up with the help of a wrench. It will come up slower this way,and you can alternate one way then the other.I did mine in the center, there was no crease and it popped right out. Paul | | | | | Joined: Feb 2007 Posts: 8 Apprentice | | Apprentice Joined: Feb 2007 Posts: 8 | Finaly found some time to work on the cab. First I want to thank everyone that responded, this really is a great site and all you fellow stovebolters make it that way. I took v6 fix modelman's suggestion and bought a stud welder from (Gup) Harbor freight. The tool worked great on the dents I have attempted to repair thus far and it appears that I will not need too much body filler. Thanks again, Brian | | | | | Joined: Aug 2011 Posts: 4 New Guy | | New Guy Joined: Aug 2011 Posts: 4 | I need to get me one of those. A tree fell on mine a few months before I bought it. Got the roof pretty good. Can't get to it from the inside because of the inner brace. | | |
