7 members (walter74, baldeagle, Wooley, Sjm, moparguy, Jman, SmalltownTRKGuy),
344
Mod | | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 20 New Guy | | New Guy Joined: Jul 2010 Posts: 20 | I want to keep my '51 Chevy 3100 looking original but want radial tires. What size tire works best? Thinking 16" x 6" wide rims. Any suggestions? Ray
Blue51
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I use 215/85 16LT on my '54 burb. I like the way it stands and rides. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I did the same as Cletis on My 52-3100 looks and rides good.
Pete | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Not trying to hijack the post but,did you Pete or Cletis use inner tubes? I've seen that suggested before with radials. About to shop for my 3100 too.
Drew
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | No tubes in modern radial tires some say they do but You're going to have a hard time finding a tire shop that would install them ,I didn't and I'm having no trouble with my tires ,take the tires off then clean the inside of the rim remove all and any rust sand it down good make sure where the tire seals is clean.
Pete
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I didn't use tubes either. I had new wheels from Stockton put on stock centers. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I use 215/85 16LT on my '54 burb. I like the way it stands and rides. 55k miles on a daily driver only vehicle, used Michelin 215 85R 16's look stock. I originally had a gently used set that I put 45 K miles on and they were still (barely) legal when I bought the new set. Stock rims no tubes, no flats no problems 10+ years.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
