8 members (78buckshot, 2-Ton, Gdads51, Wheelie, Deegs53, Peggy M, Gray_Ghost, 1 invisible),
150
Mod | | | Forums66 Topics128,078 Posts1,056,024 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Morning all. I've already searched through the forums and apologize if I'm asking something that's already been covered. I'll keep it short and simple. I have completley rebuilt my 64' with the original 230 and 3 on the tree. After driving it for over a year now I've decided to replace the original 3 speed with an OD. Can anyone out there tell me please if they have done this and what they used with both the good and bad? I have given thought to a Saginaw 4 speed,S10- T-5,SM420, 4 speed using the tree shifter and a cble under the dash for reverse, etc.... Got to do something to get the rpm's down on the hiway. Thanks Tramp | | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | in the dallas craigslist is a 3 speed OD that will bolt into your truck, make sure you get the wiring harness, relay, and od lock out cable. Make sure that the OD unit stays full of oil, if not it will lock up or break. It always keeps the ool to the main gear case. if not, go with a 200r4 which has vacuum shift. If you go with a sag 4, change your rear end to use 4th as an OD
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The simplest & probably cheapest & best in some opinions is the T-5 from an S-10. The Saginaw or SM420 will not give you o-drive. The 3 speed 0-drive like Dw is refering to is good but they are a little hard to find & some parts for them are real hard to come by. There is info in the tech tips & much info in previous posts about the T-5. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
