3 members (mk72, MT53, UtahYork), 100 guests, and 4 robots.
Topics128,186
Posts1,057,315
Members48,468
#711575 01/13/2011 8:34 PM
Where can I find the specifications of the drive shaft parking brakes ?
Since still ill I haven't had time to investigate, but the handle goes to bottom with no effect at all. So I'm in for a rebuild of park brake.
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
Or adjustment.
Check your service manual first, then have a look see at what you have under the truck.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #711583 01/13/2011 9:09 PM
I know it's a drive shaft e-brake. We have the same here in Sweden on the old Volvo Army 4wd vehicles.
I have no service manual. Will try to find it on the net...
Of course I will try adjusting if possible... =)
[email protected]
Also:
There are a few different types of drive line brakes that come on these trucks. The most common has a drum with an inner and outer shoe, then there is one with a band around the outside of the drum and still another has two shoes in the drum. All three of these brakes have different adjustment methods.
The most common having the most complex adjustment start by ensuring that the brake is completely released and the wheel are chocked then loosen the jam nut on the bolt at the bottom that pushes up on the outer shoe. screw this bolt in to obtain a clearance between the shoe and drum directly above the bolt of .010" to .015" and tighten the jam nut. To the right side of the bolt that you just adjusted at the end of the bell crank that applies the force to the two shoes is a J bolt adjust the top nut on this J bolt up then the bottom nut up till you get a clearance between the inner shoe and the drum of .010 to .015 and tighten the top nut back down to hold this adjustment.
The other two types are pretty straight forward and only have one adjusting point.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Thanks, I will surely save this for future use !!!
[email protected]
Also:
Here's a link to the '51 Truck Brakes Service Manual that I used to understand how the propeller shaft parking brake operates.
Shom #712599 01/17/2011 8:00 AM
That's exactly the brakes I have !!
Thanks...
[email protected]
Also:
