3 members (Hotrod Lincoln, delky, Rich'sToys), 69 guests, and 3 robots.
Topics128,179
Posts1,057,157
Members48,465
it's not done yet, but it started as a 1 1/2 ton hay hauler flat bed. frame has been shortened (obviously) and i took 4 leafs out of the front to lower front end. as you guys know w/ the big bolt, parts are difficult at best to find. "fits 1/2 ton only" sound familiar to you.... I'll post more as it comes along. -DVZ
http://s1231.photobucket.com/albums/ee502/dvzdeathtrap/
Looking at your front axle dust caps, i'd say your truck started out life as a 16000lb. gvw 2 ton. Neat 'lil rig.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
possibly. i bought it from a friend at work whos father died about 2 years ago. no one else in the family really knows much about the truck. it just says 1 1/2 ton on the title. i love how solid it is though. they REALLY don't make em' like they used to. -DVZ
Yeah, The 2 ton trucks have bolt on dust caps, the 1 1/2 ton have press on caps. Also check your ID plate in the driver door jamb. If it's 16000lb. gvw it's 2 ton, 14000lb. 1 1/2 ton, regardless to what the title says.
Spanky Hardy
1950 GMC 250 1-Ton
good to know. thanks. -DVZ
Thats a cool truck you got there.. did you shorten it or was it that way when you got it?
does this apply to all years of trucks.. my 36 has bolt on caps.. but was told it was a 1.5 ton as well.. ???
i appreciate that. no the guy that owned it before me shortened it. That was my original plan when i was going to look at it, before i saw it. It's shorter than what i would have done, but oh, well. it's different. -DVZ
Nope, Dust cap theory doesn't apply to your '36 model. Chevrolet's first 2 ton rated truck wasn't until 1946.
Spanky Hardy
1950 GMC 250 1-Ton
3B Offline
Hy Guys, this may get lost here, but the 1 1/2 ton dust caps with the eight sided head SCREW into the hub, they are not pressed in, very fine thread but definately SCREW in, hope that helps.
