| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 9 New Guy | | New Guy Joined: Aug 2009 Posts: 9 | After replacing the ball joints in my 1962 c10 how do I set the torsion springs to factory specs.Thanks, Scott | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Scott,
If you look under the truck's cab you will see where there is a BIG square nut that adjust the ride. BEFORE YOU TRY TO MOVE THEM, First soak the hell out of them with Kroll Oil or PB Blaster or WD-40. God only know when they were last moved/adjusted. IF you break the bolt or nut, you'll have to dig through junk yards or a scrapped truck to find a correct replacement.
Measure the height of the highest point of the front wheel well fender rim to give you a referance point.
After you feel that the nut has soaked enough, take a 6 point socket (You don't want to strip these) and slowly losen or tighen the nut on the bolt. | | | | | Joined: Aug 2009 Posts: 9 New Guy | | New Guy Joined: Aug 2009 Posts: 9 | Thanks for reply V-6 Fix Modelman. I undrstand how to adjust them.I just dont know what the factory specs are for front fender to tire height clearance.Thanks scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The ride hight measurement is taken at the bottom edge of the crossmember ti thetop outer flange of the lower suspension bumper bracket on the control arm. The spec is 4 1/2".
Bill Burmeister | | | | | Joined: Aug 2009 Posts: 9 New Guy | | New Guy Joined: Aug 2009 Posts: 9 | Thanks longbox55.Im sorry im dumb. Im trying to picture in my mined the exact point your describing.Ive even got my factory assembly manual in my hand.Ok i know ware the lower supension bumper bracket is on the lower A arm.But im not sure about the spot to measure from on the crossmember.do you mean the upper A arm?Thanks Scott | | |
