4 members (Jon G, Joe H, 68ironhead, GMCJammer51), 125 guests, and 5 robots.
Topics128,078
Posts1,056,046
Members48,433
#711148 01/12/2011 5:28 AM
After replacing the ball joints in my 1962 c10 how do I set the torsion springs to factory specs.Thanks, Scott
Scott,
If you look under the truck's cab you will see where there is a BIG square nut that adjust the ride. BEFORE YOU TRY TO MOVE THEM, First soak the hell out of them with Kroll Oil or PB Blaster or WD-40. God only know when they were last moved/adjusted. IF you break the bolt or nut, you'll have to dig through junk yards or a scrapped truck to find a correct replacement.
Measure the height of the highest point of the front wheel well fender rim to give you a referance point.
After you feel that the nut has soaked enough, take a 6 point socket (You don't want to strip these) and slowly losen or tighen the nut on the bolt.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Thanks for reply V-6 Fix Modelman. I undrstand how to adjust them.I just dont know what the factory specs are for front fender to tire height clearance.Thanks scott
The ride hight measurement is taken at the bottom edge of the crossmember ti thetop outer flange of the lower suspension bumper bracket on the control arm. The spec is 4 1/2".
Bill Burmeister
Thanks longbox55.Im sorry im dumb. Im trying to picture in my mined the exact point your describing.Ive even got my factory assembly manual in my hand.Ok i know ware the lower supension bumper bracket is on the lower A arm.But im not sure about the spot to measure from on the crossmember.do you mean the upper A arm?Thanks Scott
