| | | Forums66 Topics128,160 Posts1,057,051 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | it's not done yet, but it started as a 1 1/2 ton hay hauler flat bed. frame has been shortened (obviously) and i took 4 leafs out of the front to lower front end. as you guys know w/ the big bolt, parts are difficult at best to find. "fits 1/2 ton only" sound familiar to you.... I'll post more as it comes along. -DVZ http://s1231.photobucket.com/albums/ee502/dvzdeathtrap/ | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Looking at your front axle dust caps, i'd say your truck started out life as a 16000lb. gvw 2 ton. Neat 'lil rig. | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | possibly. i bought it from a friend at work whos father died about 2 years ago. no one else in the family really knows much about the truck. it just says 1 1/2 ton on the title. i love how solid it is though. they REALLY don't make em' like they used to. -DVZ | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yeah, The 2 ton trucks have bolt on dust caps, the 1 1/2 ton have press on caps. Also check your ID plate in the driver door jamb. If it's 16000lb. gvw it's 2 ton, 14000lb. 1 1/2 ton, regardless to what the title says. | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | good to know. thanks. -DVZ | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Thats a cool truck you got there.. did you shorten it or was it that way when you got it? Yeah, The 2 ton trucks have bolt on dust caps, the 1 1/2 ton have press on caps. Also check your ID plate in the driver door jamb. If it's 16000lb. gvw it's 2 ton, 14000lb. 1 1/2 ton, regardless to what the title says. does this apply to all years of trucks.. my 36 has bolt on caps.. but was told it was a 1.5 ton as well.. ??? | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | i appreciate that. no the guy that owned it before me shortened it. That was my original plan when i was going to look at it, before i saw it. It's shorter than what i would have done, but oh, well. it's different. -DVZ | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Nope, Dust cap theory doesn't apply to your '36 model. Chevrolet's first 2 ton rated truck wasn't until 1946. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, this may get lost here, but the 1 1/2 ton dust caps with the eight sided head SCREW into the hub, they are not pressed in, very fine thread but definately SCREW in, hope that helps. | | |
