| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I have a '48 1.5ton with 20" wheels and a 5.4:1 rear axle. Instead of all the work of a 5-speed, I figure I can get the same end result (60 mph cruise) by installing a taller ratio diff. I have been looking at options and the rear axle in a 55-58 Chev 1.5 ton LWB pickup appears to have the same diff head unit. But on 15" or 16" rims- with a 4.5 ratio. Can anyone confirm this? Swapping diff heads is a morning's work. easy. Finding the right one not so easy.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have not heard about this swap, but then again we didn't have a 1.5 ton pickup over here that I know of.
Let us know what you figure out!
Grigg | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | Casting number on the 1.5 ton diff head is 36522??, maybe 3652280. The casting is 350mm/13 3/4" diameter at the mounting face. 1115 mm/43 7/8 inches circumference, and is retained by 10 bolts. The rear cover is 340mm/13 1/3 " diameter, also retained by 10 bolts.
| | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | If the spring width is the same, you would be quicker swaping out the entire rear end. | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | The spring width is probably different. I have a big bolt, dual 20" wheels, the later smaller apache has single 15 or 16 inch wheels, but i read somewhere, fully floating wheel bearings.
