| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 53 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 53 | I have a 1950 Chevy 3100 with a 216 motor. I am trying to get it back together and I have had it apart for 20 years. I took the flywheel off and at the time I was looking to replace the locking tab plates under the flywheel bolts. Not only did I not find replacements - I lost one of the ones I had. Any ideas where I might locate these little gremlins? Thanks, Jerry
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Red LocTite is your friend! You could also cross-drill the bolt heads and use aircraft type safety wire to secure the bolts. I'd suggest using the LocTite, along with the correct torque.
| | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I have made them with some sheet metal. I actually used brass, but any sheet metal material would work.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
