0 members (), 53 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#7106 06/12/2003 1:54 AM
Hello world...do ya think that a '47 chev (with a '57 235 transplant) has a pressurised coolant system? If so, what pressure rad cap is advisable? Cheers!
#7107 06/12/2003 2:57 AM
47 chev,
I understand that the recommended pressure caps for '54 and later 235 engines were 4 psi in a truck engine and 7 psi in a car engine. I think that earlier truck engines (216 and 235) both had 0 (zero) pressure radiator caps.
Maybe someone else knows if pressures greater than 0 psi were safe with other '47 parts (specifically, radiator and water pump).
Someone will correct me on this, if I'm wrong.
Tim
#7108 06/12/2003 2:58 AM
Probably 4 pound, but get a shop manual for it to be sure, the manual will come in handy for a lot information and help.
#7109 06/12/2003 3:16 AM
I have a 7# on my 54eng 235,works fine for me, in fact I go in a lot of stop and go on the interstate today, and it was also a very warm day about 93, the truck never got pass 185..good luck..Fred
Redryder pix
My Hotrod
#7110 06/12/2003 5:44 PM
I would start with 4 and only go up if you have overheating problems. A pressure system allows more heat transfer because it allows the water to be hotter before it boils over. If it doesn't boil over at 4 then leave it alone, it will be easier on the seals. 7 may be safe but I wouldn't go there unless you need to.
Paint & Body Shop moderator
#7111 06/12/2003 5:58 PM
Mine came with a 7 and I changed it to a 4 and it runs at the same temp in hot weather. So, I figure it is safer on my old radiator.
54 3100 with 235
62 flatbed dump C60 with 261
#7112 06/12/2003 6:22 PM
My 50 3/4 ton had a 0 lb. cap on the original radiator and a transplanted 307 V8. Worked great summer and winter. I tried a 4 lb. cap and my radiator started leaking. Good luck
Professional Novice
#7113 06/12/2003 6:32 PM
My 52 year old radiator leaked with 0# cap....really leaked with 4# cap grin
New radiator solved everything at 4#.
PRW
