| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | Hello world...do ya think that a '47 chev (with a '57 235 transplant) has a pressurised coolant system? If so, what pressure rad cap is advisable? Cheers! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 47 chev,
I understand that the recommended pressure caps for '54 and later 235 engines were 4 psi in a truck engine and 7 psi in a car engine. I think that earlier truck engines (216 and 235) both had 0 (zero) pressure radiator caps.
Maybe someone else knows if pressures greater than 0 psi were safe with other '47 parts (specifically, radiator and water pump).
Someone will correct me on this, if I'm wrong.
Tim | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Probably 4 pound, but get a shop manual for it to be sure, the manual will come in handy for a lot information and help. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I have a 7# on my 54eng 235,works fine for me, in fact I go in a lot of stop and go on the interstate today, and it was also a very warm day about 93, the truck never got pass 185..good luck..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would start with 4 and only go up if you have overheating problems. A pressure system allows more heat transfer because it allows the water to be hotter before it boils over. If it doesn't boil over at 4 then leave it alone, it will be easier on the seals. 7 may be safe but I wouldn't go there unless you need to.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Mine came with a 7 and I changed it to a 4 and it runs at the same temp in hot weather. So, I figure it is safer on my old radiator.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | My 50 3/4 ton had a 0 lb. cap on the original radiator and a transplanted 307 V8. Worked great summer and winter. I tried a 4 lb. cap and my radiator started leaking. Good luck
Professional Novice
| | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | My 52 year old radiator leaked with 0# cap....really leaked with 4# cap New radiator solved everything at 4#. PRW | | |
