1 members (JW51), 115 guests, and 0 robots.
Topics128,081
Posts1,056,078
Members48,434
#709890 01/08/2011 12:17 AM
I've got all the stock suspension under my truck and would like to lower the front. Is removing a few leafs the easiest/cheapest way to go?
or for a hundred something bux you can buy new mono leafs that will lower up to 3" i believe. probably safer too.
its not the easiest or cheapest but if you went with a different front clip with some drop spindles It would drop your front 6 inches! And in the process update your suspension, brakes, and steering! win win!
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
What if you changed out the rear of the front spring,, spring hanger''
bringing it up closer to the chassie this would give you a few inches maybe. Now my question.. is there a new type hanger avaliable or would you have to make it?
I am considering such a move with the rear spring front hanger, i have lowered the front end with 2'' drop spindles, now working on the rear.I was just going to start a topic when i saw this one.
What do ya think?
layback
laybacklenny,
shortening the leaf spring shackles would lower the truck you are correct. It would give you how ever many inches you shortened it (obv.) I am sure you can find them somewhere for the mear fact that some guys shackles are rusted out and need replacement. I will look around.
My Project Bolt
Hi Guys,
I have a big bolt and would like to get the front to look exactly like this.
http://sphotos.ak.fbcdn.net/hphotos...91212992_1852033637_597178_4013845_n.jpg
Would reset springs and a dropped front axle get me to this? I have put a message in the thread with the owner of this truck but thought it could help with anyone searching in future.
Cheers
Damian
i am not sure I would have to see the axle setup underneath the skin. I am not sure the bones on these big bolts.
My Project Bolt
I have no advice on how but i would decide on a end plan and try to go there directly. this will save time and most importantly MONEY in the long run.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Shortening shackles will lower, for sure, but might limit the movement of the spring.
And remember there are other things to consider, like geometry and clearances. You could end up with the look you want, but it would be a [censored] to drive.
Coneboy, how low do you want to go?
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
laybackkleny: You say you dropped the front end with 2" dropped spindels. On an I beam axle? If so what spindles did you use? That would be easier than a dropped axle
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
I guess the big question is: How low can I go with the stock axle and still maintain drivability?
Saving American history one rust bucket at a time. When they're gone, they're gone forever!
mo Offline
measure out your springs eye hole to eye hole and hit the junk yard for a set with less curve would be the cheapest or hit the aftermaket for a monoleaf or lowering springs
MO's 1951 chevy 3100 resto mod project
mo #817033 01/17/2012 4:48 AM
www.droppedaxles.com
Sid is THE man when it comes to dropped front axles for these old trucks.
Marty
^ x2 on www.droppedaxles.com
Nostalgia Sid is indeed THE man. Awesome guy and a great product. I bought a 4" drop axle off another stovebolt member and Sid has been more than happy to spend time with me on the phone on numerous occasions just chatting thru things.
I'll be buying my rear blocks and anything else I'll end up needing from him simply because he's been that helpful.
Thanks guys for the good words. I'm always here to help on any axle questions. I'm just not a axle dropper I love any old cars. I've made many friends in the old car world by just helping other car nuts out. Who cares if they are a customer or not if they need help. I was a old car nut before I was in business.
Anybody removing a dropped axle to install an IFS unit? No room in the budget right now for a new "Sid's". Sure would love to have one though.
