| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 21 New Guy | | New Guy Joined: Jan 2011 Posts: 21 | Ok, need help. Just picked up 1941 Truck. Have to assume 1/2 ton from look at rear end. The number stamped on block right behind Distributor on Passenger side says BA682343. Which is the same number on the Title. It is an inline 6. Help?! http://s1191.photobucket.com/albums/z468/MortgageLaw/1941%20Chevy%20Truck/ | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Nice truck. That looks like a Packard steering wheel.
I have an engine book at the shop so I can't look it up for you now. Someone probably will soon though. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Looks 216 to me and from the numbers it appears it is original as far as I can tell. I'm not an authority here, others will tell you the exact info. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2011 Posts: 21 New Guy | | New Guy Joined: Jan 2011 Posts: 21 | Looks like your link to the spec sheet hits it on the head. So, the code says 1942 216. So, can a 1941 have a 1942 engine, I think so. Well, it is a great start. Now, to get this engine rebuilt. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Your truck may actually be a '42, rather than a '41. Some states used to title the vehicle based on what year it was sold, rather than what model year the vehicle really was. With most manufacturers putting the next years model out usually between late August to early December, it's entirely possible for a '42 to get registered as a '41 if it was sold prior to the calender year change. It shouldn't make much difference in this case, as the '42 was essentially a carryover of the '41.
Bill Burmeister | | | | | Joined: Jan 2011 Posts: 21 New Guy | | New Guy Joined: Jan 2011 Posts: 21 | Starting to make since given the numbers on the engine etc. One I remove the aftermarket heater I will have access to the plate the trucks serial number should be on, assuming it is still there and under it I will confirm.
thank you | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I'd like to better understand the connection between the heater location and the ID tag. Can you explain please, and perhaps show a picture or two? Thanks | | |
