7 members (Bill Hanlon, Oswald, elhippie64, moparguy, 1955 1 Series, Southerntruck, 1 invisible), 99 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#7101 08/17/2003 1:36 PM
Junior Member
Junior Member
I have a 1961 chevy apache 10 4x4 the 235 has some serious issues and a want to install a 305 that I recently purchases and am having som problems. is there any kit I can get that will work? or any other Ideas will be great also it has a 4 speed will the bell housing work of the 235 or what can I get one off of. I would appreiciate any help thanks
jr Offline
Junior Member
Junior Member
Hi,
I've got a 45 2 ton with a 235. My plan is to swap in a 86 305v8. So anything you learn would be helpful to me. So far I have not pulled either engine so I can't say about tranny boltup or such. For now I am working on the left motomount wedge. I plan to leave the orig. steering gearbox where it is and that's right in the way. With luck, I'll be able to work something out.
Let me know how your project workes out.
BTW are you westriver or east. My roots are in Sturgis and that's were my 45 sat for nearly 50 years.
You will need a V8 bellhousing. Measure the transmission input shaft to make sure the hole is the right diameter on the bellhousing, there were two differant sizes.
Paint & Body Shop moderator
I have read somewhere that the 2 motor mounts( 1 short and 1 long)you have now. Will be no good to you, well thats half true. You will need 2 of the long ones. This will give you the set up for an 8 cyl....
I am pulling this from the back of my mind and I am offering this info and stating "Don't quote me on this tho'"
<center><img src="http://www.angelfire.com/ns/2xcapers/images/GMC_910_avatar.gif" alt="3 speed burnout">
Turn them Tires, so ya can
smoke 'em and choke 'em
[Linked Image from angelfire.com]
Vic... '65 GMC 910
Hey heres an info page on that. I found it in my favorites..Hope it helps..
http://www.geocities.com/vapershing/perches.html
Vic... '65 GMC 910
