2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Junior Member
Junior Member
Is anyone using this Terf Inc. speedo adaptor?
Terf Inc.
Junior Member
Junior Member
Quote
Terf Inc.
Seems like a step back, are you wanting to use this to keep the factory speedometer on a newer trans?
48-54 Chevy light duty
Junior Member
Junior Member
Yes, thats what I want it for...I called the guy. They are on backorder till the end of the month. He said this will work but I would like to hear from you guys...
I used the cable-x controller www.abbott-tach.com
Works great.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
U
U Offline
Wilbur, What was the cost of the converter? They don't list it on the link you provided? Thinking of using on on an S-10 5 speed. The only ones I have been able to find have the electric speedo on them.
Junior Member
Junior Member
The Abbot is $300. The Terf is $150.
U
U Offline
Tractorboy, What transmission are you trying to convert to mechanical? Plan on calling them today. Found a S-10 trans for $100 but electric speedo. $150 for converter+trans is still less than the $$$$for a strictly mechanical.
Any one else using the Terf adapter???
Junior Member
Junior Member
I also have the T5. I actually have an extra blown t5 mechanical. The tail end is still good but its missing the speedo (part that cable screws onto). I figure the cost of that part plus the cost to swap tail sections plus cable extension,....that Terf looks pretty good. Plus you can tune the Terf for different tires.
Let me know if they got any in...
1 Offline
Terf Inc. told me $280 for adapter. Kinda spendy adapter.
