| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Any thoughts out there about using Flange style nuts to replace old nuts on 54 3800 Dually ?
Would like to replace 1/2 - 20 lug nuts.
Quick search seems to tell me lower grade nut to higher grade bolt ? 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | lower grade nut & higher grade bolt is correct. that way the nut (which is easier to replace) strips before the wheel stud. the flanges on the newer style nuts would perform the same task as the ring that's probably under your lug nuts now. I don't think one way would be any better than the other, it would just depend on what you like & what you want. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | just checked out your photobucket shots. that truck is beyond COOL! I really like the bed, looks really versatile. does it dump? are you going to use the NV4500 with the pto drive in it? keep us updated it looks like a really neat project. | | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Hi bluechev...thanks for your feedback. The PO had standard nuts with thick fender washers, I don't like that setup much. Don't have the large ring, so I thought the flange nuts was the best choice. Just didn't know if "LUG NUTS" are graded...3,5,8
Yes it does dump, have to put some updated pics online. I have a 292 to go with the NV4500. Could go with mechanical PTO or use the Elec/Hydr PTO that is on the NV4500...still think about that.
Have been working on brakes lately...added dual master & updated the fronts. All new in the rear last year. 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | cool, I've got a booster/master from a 67 1 ton I'm going to put on my truck pretty soon. you can get 1/2" 20 grade 5 flanged nuts ( typically called "wiz nuts") from any nut & bolt supply house.
| | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Thanks Robert...Are you installing the '67 booster/master under the floor ? I'm looking at Wilwood master with remote resevoirs. I plan on doing the Dodge Disc/caliper upgrade in the near future and move the battery to frame behind cab. RE: full floor carpet. Don't know if I will use a booster yet.
I've have a good local hardware store that has the Flange nuts, on my list for this week. 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
