7 members (Ponchogl, Otto Skorzeny, 39Master85, Southerntruck, 50Chevy3100, BC59, 1 invisible),
136
Mod | | | Forums66 Topics128,090 Posts1,056,345 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Does the air cleaner come apart to allow R&R of the foam insert? Somehow I have not figured that out!  Thanks!
1956 Chevy 3600 Dually
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not about to tell you there's no such thing as a foam oil bath filter because I really don't know but all of the oil bath filters I've seen have copper gauze as the filtering agent. There are vendors that sell replacement copper gauze so there must be a way to change it out. I'm sure someone will chime in with more knowledge about it than I have. Good luck.
| | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | I have some off a Studebaker that are around the same age and they come apart. Once you take the lid off and dump out the old oil, you can clean the bottom half easy enough. In the lid section you should see a snap ring around the center section, mine was on the out side squeezing inward. Pry this off then the two sections will come apart. I had to pry mine apart since its a press fit on the outer edges. The horse hair looking stuff can then be washed.
Joe | | | | | Joined: Nov 2006 Posts: 37 New Guy | | New Guy Joined: Nov 2006 Posts: 37 | cfesting:
This tip was passed along to me. I haven't tried it as my truck seems to be in a million pieces. But I will use it when it gets back running.
It's horsehair. Just wash out bottom of assembly as best you can and fill it to the line or arrow pointing down with ATF and this will make it self - cleaning , the next 3,000 mile routine service you'll notice a buncha silty sediment in the bottom of the oil cup , wipe it out , re-fill with fresh ATF and motor on happily . in time you'll find less and less silt in there as the horsehair cleans and runs the dust back into the oil cup after you shut it off...
The brand or typ of ATF isn't important , I use the cheap stuff from the .99 CENTS store. Don't use Typ F or your engine will _explode_ .
Hope this helps,
Kent S Butler '56 Chevy 3100 Houston, TX
