1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#70936 01/01/2007 6:26 PM
Hi guys, Im new to the board. Glad I found yall! I've had this truck 20 yrs and have not done much to it. It is a 65 stepside, I think it was a 6-cyl 3-spd on the tree orig, but had a 72 350 ci and floor shifter when I bought it. I think I would like to update the front end, pwr steering & disc brakes. Also install auto trans & A/C. I've changed the rear end before, and tranny a couple of times, and pulled the motor twice. but I never attempted front end work. Im a working man, not a collector. therfore on a limited budget. Whats the best way to go, Is there a yr mod truck that I can swap my body over to without a lot of fabricating. I don't know if I would be exp. enough to try and weld a front clip on. And I've seen the ads in magizines for new front end parts, i think about $2k. I'm kind of lost, having never done any susp. work, except changing shocks & brakes. Any advice or feedback will be greatly appreciated.
Riding in the Passing Lane
That model has a good stout front end under it. You don,t need any wild changes. There is a kit available to put 67 up power steering on & kits available for disc brakes. The 71 up disc brakes fit with some minor changes but you wind up with 5 hole hubs. There are lowering spindles out there too but I like stock height. Do some research there is plenty of info out there & parts. Jack the front wheels up under the a-arms & shake & pull the wheels & watch for any looseness. Replace any worn parts & line it up good & you will have a great driving truck.
1972 Chevy c10 Cheyenne Super
Z
Z Offline
if you want to lower the truck,you can get dropped spindles for around 230 dollars that will drop it 2.5" and allow you to bolt on disc brakes from a 73-87 c10.the front suspension is almost the same from 1963-87 power steering too.this is what i did.you can buy six lug rotors too.
It depends on how deep your pockets are. If you're on a budget and are willing to switch to 5 lug, find a front crossmember with power steering on a 71-87. You will have to drill some new holes, but it's almost a bolt in swap. If you want to go 6 lug, here's a link. http://67-72chevytrucks.com/vboard/showthread.php?t=35042
Fred
52 3600
69 C-10
Try Classic Performance Products. They have lots of options. I bought parts off a '67 disc brake donor (swapped whole front cross member). This was pretty simple too.
1 Offline
I agree with Fred T a 73 thru 87 C10 will work awesome on the 58 thru 66 and its a easy install I bought one to install on my 51 but my frame is almost 2" to narrow and was told that its a perfect set up on yours because the frame is the same width as the 73 - 87. just drill a few hole and bolt it in !
Good luck
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Now I feel a lot better! I've got to thank you all again. A while back I picked up a 76 with a blown engine for $200 and was going to transfer the P/Steering and piece together the brakes onto the 64. The more I looked at it the more I was thinking that the whole subframe should be swappable! Seems like I was on the right track now after reading your thread. So I should be able to order a set of the 6 lug disc to match my rear end, well the truck's rear end.
My other truck is a Ducati
