6 members (Otto Skorzeny, TexasJim50, joe apple, RaNfLaS, Hotrod Lincoln, Wayne67vert), 127 guests, and 4 robots.
Topics128,162
Posts1,057,065
Members48,463
41 1/2 ton with very tiny leak at rear brake T-block. I've tried different copper washers and have flattened out the surface of the old t-block. Has anyone used washers made of different material, or should i just buy a new t-block and washers? thanks
I recently replaced the brake hoses on my '41 with no problems. Are you sure the leak is coming from the junction of the T-block and the hose? If so, and you're sure the parts are good and clean and the hose is screwed down tight, then you may need either a new T-block, washer, or hose. I'd be leary of using a washer made from something else for fear the brake fluid would eat it away over time.
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
Originally Posted by TooMany2count
I have had old & new washers leak.
The only thing I have found to fix them is rub them on the concrete floor (yep you read that correctly
i have done that also with success. i think on the floor the washers scuffs up enough and evenly to get it to seal properly. the floor makes an excelent sanding block.
Make sure the threads on the bolt are clean, also make sure surfaces are mating square. Sometimes over tightening can cause minor leaks also.
thanks for the tips. i'll give them a try this weekend.
