7 members (fonz8261, 1955 1 Series, FrankenChevy, 78buckshot, Gdads51, Gray_Ghost, 1 invisible),
100
Mod | | | Forums66 Topics128,180 Posts1,057,067 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | 41 1/2 ton with very tiny leak at rear brake T-block. I've tried different copper washers and have flattened out the surface of the old t-block. Has anyone used washers made of different material, or should i just buy a new t-block and washers? thanks | | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | I recently replaced the brake hoses on my '41 with no problems. Are you sure the leak is coming from the junction of the T-block and the hose? If so, and you're sure the parts are good and clean and the hose is screwed down tight, then you may need either a new T-block, washer, or hose. I'd be leary of using a washer made from something else for fear the brake fluid would eat it away over time. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I have had old & new washers leak. The only thing I have found to fix them is rub them on the concrete floor (yep you read that correctly i have done that also with success. i think on the floor the washers scuffs up enough and evenly to get it to seal properly. the floor makes an excelent sanding block. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Make sure the threads on the bolt are clean, also make sure surfaces are mating square. Sometimes over tightening can cause minor leaks also. | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | thanks for the tips. i'll give them a try this weekend. | | |
