0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The knob on the side of the distributor is actually for lubrication of the distributor shaft bushing. It would be filled with grease, then the knob is turned 1 turn every 1000 miles to force grease into the bushing. Unfortunatly, many times this was not done, and the bushing runs dry, leading to prematrue shaft wear. To answer the second qustion, if you're looking for a true HEI, you would be changing out the entre distributor, there isn't a way to convert. Langdons has HEI distributors that are already modified to work in the 235. If you mean to eliminate the points, Pertronix makes a kit that will work in your existing distributor.
Bill Burmeister | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Be sure that you don't loose part number 4 ,it's really easy to misplace it. distributor parts diagram Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Great...I didn't have a #4 in my housing...Now Where can I get that and how does it go in???????? And Yes I just want to go with Pertronics and use my distributor...Any Idea what kind of grease goes in the cap? Thanks
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Jimmi, Thank you for bringing this up. You have exactly what I have and are a step ahead of my very same questioning. GOOD information here! BTW I didn't have a part #4 in my assembly either! Denny, this is the felt item you are referring to? The spring compresses it? Jerry | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Re-posted the some pix Jerry, take a look. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Felt may work OK but originally the disc is some kind of plastic. I make new ones out of Nylon on my lathe for the ones I work on where the disc is worn out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Sorry, I can't view the pictures from work (company filters certain websites) so I'll have to wait till I get home. I'm not getting how this works though... usually a spring pushing aganst a plug denotes a type of check valve. But screwing in the cap adds grease via pressure?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The spring and disc are used to keep the slop out of the shaft, this keeps the point gap uniform. The grease cup lubes the wear disc.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The disc is some type of fibre or plastic,they're solid material.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The "fibre plug" in mine (three 1954 and later distributors) are as as Tim described: fiber/plastic, hard-material.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dave that's what I used to think and I'm sure that I've taken phenolic discs out of them when I've rebuilt them. But the parts books show only felt wicks for the 216 and 235 and there is no listing of a disc. Actually a felt wick makes more sense, I always wondered what the purpose of a phenolic disc was, seemed like it was just an invite for trouble to have it rubbing on the shaft. I've often wondered if the disc wasn't between the spring and the felt wick originally and the wicks were simply worn away from 50 years of use. Or if originally one side of the wick had the phenolic bonded to it. I’ve machined little brass plugs to push against the felt before. In fact I’ve got a spare here left over from the last ones I made. http://www.pbase.com/dennygraham/image/131631563/large Denny Graham Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Denny, The parts book Tim linked to above (item #4) calls it a "Fiber plug". I have had a lot of these apart and it looks like some kind of plastic to me. Who knows.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Just a minor correction: Fibre Plug is how item #4 was spelt in the diagram for which Tim gave the link above.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's what these pictures are from. When I pulled it apart there wasn't any felt or fiber in it, the spring was simply rubbing against the shaft. It apparently didn't do any damage because I had the shaft out and there weren't any marks on it. Denny G
By the way Tim, package was shipped this morning, should see it on Friday.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, This is weird, I see in your link it calls it a wick/felt. I have had a lot of 216 and 235 distributors apart and they all have had the same hard plastic disc.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, Bakelite makes more sense.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | We need someone with a nos distributor to take a look.I know just the guy that may have one or two of them.I will try to get in touch with him in the next few days.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good idea, Tim. This is interesting. (how sad -- "this is interesting") | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now you want to really cornfuse the issue, look at this illustration for the '55-'57 and they show a lock washer in line with the spring in the exploded view. http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0224.htmNow I'm really getting screwed up, and I'd still like to hear a logical explanation why you would put an abrasive material spring loaded against a ground and polished shaft??? I think the engineers took a break and turned the illustrations over to the technical writers. I had a friend once that was a technical writer and he couldn't screw in a light bulb, but he could tell you how to do it. Denny Graham Sandwich, IL
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Man alive what a great topic...keep going boys I'm enjoying the education. I won't do anything till " We " figure out whats what. Thanks | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | It looks like the 1941 Parts manual calls out a part number for the "Plug, fibre". The 1954 and 1957 parts manuals do not seem to show that part in the 2.364 group listing. Hoyt | | | | | Joined: Oct 2010 Posts: 45 New Guy | | New Guy Joined: Oct 2010 Posts: 45 | How much clearer can this be? Bakelite! Now that we know what it is, what is/was it's purpose?
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | The diagram shows the plug but not the wick. Look on the next page under "Care and Adjustment".
"Place a drop or two of oil on the felt wick in the distributor cam, tighten the grease cup a turn every 1,000 miles... "
I think the plug in this example is serving as a seat between the wick and spring.
By definition, a wick's purpose is to convey liquid (lube) by capillary action. Tightening the grease cup is like pumping pressure in a kerosene lantern. I understand the principle now. I don't have a wick or plug in my unit but I'll take care of that. This has certainly been informative!
Jerry | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Difficult to tell without actually having the parts in front of you and in their original wrapper but in that group; the 816803 Wick, shaft oil - would probably be the one that is under the rotor to lubricate the cam. The 802692 Wick, grease. cup spring - would probably be the one that we are talking about here. The 1845715 Spring is as noted to hold the (felt wick). The 1869303 Plug, fiber (in grease cup hole) is in there also but once again, god only knows for what reason. Think we need to clear up the thing about the Bakelite that would have been used in the plug. Bakelite, Micarta, Garolite, Phenolic sheet is all the same thing. Could have been made with cellulose paper, cotton or linen fabrics, synthetic yarns, glass fabrics. For this plug that apparently rode on the distributor shaft, I would imagine they would have used on of the natural fiber laminates. McMaster Carr has sample sheet assortments if one is looking for some of this material to make “Bakelite” components out of. It’s available from them in 12”x12” sheets in various thicknesses and in rod form which one could use to make new plugs if that‘s what you would like. The grade CE rods are available in 5/16” and are made with a cotton-cloth laminate which would be about the least abrasive. Cheap to, just a couple of bucks for a 48” rod. If your gonna get serious about restoration, then you need to book mark McMaster Carr. I place an order with them several times a month. They will deliver the next day in most cases, have no minimums and stock tons of stuff to duplicate the raw materials that the factories used to make the parts. I hate to sound like an SOB or unfriendly, but I often get requests for parts, I keep a small supply of material for my restoration work. I’m not a supplier of raw materials or finished parts so please don’t ask for the parts that you may see me making in the pictures, I make them for my own restorations and only post the pictures to share my methods. I’m more than glad to offer any advice on sources or how I make something, but I’m not set up as a parts supplier. Denny Graham Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 45 New Guy | | New Guy Joined: Oct 2010 Posts: 45 | Denny; looking at the linked parts book, I see the 816803 but I don't see the 802692. I see only one wick listed for the six cylinder. Where did the other number come from. The service manual makes reference to removing the "bakelite shaft contact plug", spring and grease cup and replacing same; no reference to a wick.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How much clearer can this be? Bakelite! Now that we know what it is, what is/was it's purpose? The spring and disc are used to keep the slop out of the shaft, this keeps the point gap uniform. The grease cup lubes the wear disc. Dave's reply/explanation sounds good. The various references to felt and wicks (as shown in the MPCs) are confusing because there is a felt wick at the top of the distributor post, at least in the earlier distributors (under the rotor - "Shaft Felt Wick, in Cam", item #37 in the 47-51/52 Shop Manual, in link given above). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Place a drop or two of oil on the felt wick in the distributor cam, tighten the grease cup a turn every 1,000 miles... "
Jerry ""Place a drop or two of oil on the felt wick in the distributor cam, tighten the grease cup a turn every 1,000 miles... ""I think that those instructions refer to the wick at the top of the distributor post, under the rotor? Tim's suggestion that a NOS distributor, 1952 or earlier (and 1954 and later), would be the best bet on knowing what was there originally. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Getting to sound like a political debate. Think I'm just gonna run out to the barn and get some work done. I'll get back to reading this after everybody gets there interpretations and opinions posted.
dg
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Jimmi V You may have already done this, if not, now would be a good time to inspect the drive gear on the distributor. gear pic I bring this up because mine was loose and it was giving me fits trying to time the engine. I ended up purchasing a replacement distributor from NAPA. They had one in stock for about $75.00+core. I believe kits are available to re-pin the gear. Good Luck | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Mine spins freely, how would I know if it's loose...or is that obvious ? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I spoke with my contact today,and "he said he would have to take one apart and look".He said he doesn't remember ever seeing a felt wick under the fibre disc.He will get back with me,when he has time to take a look at it.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Mine spins freely, how would I know if it's loose...or is that obvious ? this is a loose gear Good Luck | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A video is worth a thousand words. Nice job.
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Dads,Thanks Man...Thats better than a picture. Just ran out to the shop and checked...mine is solid. Thats a relief.. What a discovery this Forum is...I would be hard pressed to dig this info up on my own....Man what a long way we have come....Duey decimal system to instant computer Info.....Gotta love advancement... Thanks Again | | | | | Joined: Dec 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 36 | How about the part about the octane selector/adjuster? Is that the cup housing itself? And how do you set it to zero? I don't get that part. Nice topic but I'm a little late for the party:) freezerburn
| | | | | Joined: Dec 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 36 | Just found the answer from a post by F&J. Apparently setting the octane selector to zero was another way of saying loosen the distributor bolt and turn between advance and retard (zero). In the context of preparing to time the engine that is. So there it is, and I learned alot. Thanks again stovebolters -freezerburn
