2 members (Brian Moore, panel fan), 166 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
Maybe the answer to this is obvious but I'll ask anyhow. How does one keep the cork grease seals from drying out and breaking apart? I see there are replacement neoprene ones out there but would like to try to keep them as original if possible. Obviously, keeping them from drying out is the trick. Are there any tricks out there that have proven to work?
Photo of original cork grease seals
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Cork is a impermeable natural material and will not soak up enough grease to keep them from drying out.The "life" of a cork gasket or seal is aproximatley 15 years under ideal conditions.
The good news is that cork has a high elsticity and is very dense and thus presents itself as a good cushion for the elliptical springs on your truck as they move on the shackle pins.
Keep your shackles well greased and oil the exposed cork each time you grease the shackles.The oil will act as a barrier between the weather elements,road dust and grime and your cork seals.
Hope this helps.Hobert
"The Lord is my shepherd"
Quote
That being said my NOS cork gaskets should probably be replaced. Anybody have a supplier that sells these in cork? I know Jim Carter's sells the neoprene replacements.
Tim Sheridan
I made mine out of a sheet of cork from Hobby Lobby. Made my dies out of some round tubing, beveled the outside edges of the tubing with a grinder to make them some what sharp, then placed the cork on a piece of soft wood and hit the die with a hammer. I too keep a light oil on them.
