8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible), 193 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#708529 01/03/2011 10:40 PM
I have a 3/4 ton frame...can I get front & rear axles from a 1/2 ton and bolt them onto my frame? I want to do better brakes than the huck brakes on the 3/4 ton
Apprentice
Apprentice
I have a 51 3/4 ton, took it out and bolted up an 1/2 ton original straight front axle with no problem. the issue that I have now is the rear axle, what to replace it with is my issue now. any ideas out there?
Half ton rear axles up to about '69 will be the right width for your truck and will match your six lug front hub pattern. Cutting/grinding/welding will be required for new spring pads.
Steve
'49 3800
'52 3600
'57 3100
Half Ton brakes will not be as powerfull as the 3/4 Ton brakes. In addition the larger drums give you more metal to heat up before they really get hot.
1951 1 Ton Completed
