1 members (Otto Skorzeny),
52
0
Mod | | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I have a 3/4 ton frame...can I get front & rear axles from a 1/2 ton and bolt them onto my frame? I want to do better brakes than the huck brakes on the 3/4 ton | | | | | Joined: Oct 2009 Posts: 19 Apprentice | | Apprentice Joined: Oct 2009 Posts: 19 | I have a 51 3/4 ton, took it out and bolted up an 1/2 ton original straight front axle with no problem. the issue that I have now is the rear axle, what to replace it with is my issue now. any ideas out there? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | the issue that I have now is the rear axle, what to replace it with is my issue now. any ideas out there? Half ton rear axles up to about '69 will be the right width for your truck and will match your six lug front hub pattern. Cutting/grinding/welding will be required for new spring pads. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Half Ton brakes will not be as powerfull as the 3/4 Ton brakes. In addition the larger drums give you more metal to heat up before they really get hot. | | |
