4 members (Woodcmiami, Bill Hanlon, Gray_Ghost, J Lucas), 114 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#7087 09/23/2002 9:06 PM
Anyone put mono leaf springs on a 55-59 1/2 ton?
If so, does it effect the weight carring capacity? Do the springs make it ride much better?
Thanks in advance
Shane
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
#7088 09/24/2002 3:27 PM
I don't have a TF truck, but did put monoleafs on my '51 AD GMC. I honestly can't tell much difference in the ride, but the old springs had been rebuilt and gas shocks installed, so there wasn't a very good basis for comparison. There is very little arch in this kind of spring. They are almost flat even with no load in the bed. This is why they will lower the rear up to 4" depending on how worn out your old springs are.
As for load capacity, I have hauled a fully dressed 261 (I would guess about 700 lb) with no ill effects. Since the single leaf is thinner at each end than in the middle, the leaves went almost completely flat, but didn't change the ride height much if any. I was careful not to hit any RR tracks or potholes. Whether the monoleafs would hold up under repeated heavy hauling I can't say. For occasional use they seem fine.
