0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
As part of the restoration of my '41 pickup, I'll be removing the dash for clean up and painting. I'll need to remove the choke and throttle knobs to get the dash out, but they appear brittle and potentially easily broken. How do the knobs come off? Do they simply unscrew from the cables or are they molded on, requiring the removal of the whole cable?
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
Ex Hall Monitor
Ex Hall Monitor
You'll probably have to remove the whole cable. If the '41s are like my '38 the knobs are molded to a shaft that then has a wire crimped into the end. The wire & shaft are then inserted into the cable. The whole cable is easy to remove, just unscrew the nut on the back side of the dash.
If you need new ones try THE FILLING STATION they have knobs or knobs and cabels together / on line catalog
Thanks. I did as Tiny suggested and it turned out to be an easy task to remove the knobs and cables without any problems.
My toys:
PJ 16' Trailer
Moderated by  ndkid275, Phak1
