0 members (),
147
Mod | | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | I need a dual groove water pump pulley for my 235. Does anyone have source? Thanks | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I hate to tell you, but those things are more rare than chicken lips. Really hard to find, but worth it to keep looking.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If its for a late model pump you might be able modifi one made for a v8. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | What about the dual grooved harmonic balancer,would that work ?
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | There was an interesting thread on the Inliners' BB recently on the advisability of using V-8 or 292-six multi groove damper on a 235 or 261. I have one of Buffalo's modified 292 dampers, with two grooves, on my 261. So far, so good. BUFFALO ENTERPRISES 25625 Dahl Road, Arlington, WA, 98223 (360) 652-7684 Hoyt | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I apoligize for making the statement I made and leaving you hang out there. If you are trying to make a two groove pulley for the stock water pump on a 235, here is what I did. I used a stock one groove pulley from a 350 and cut a second one groove 350 pulley to fit on the shout of the first 350 pulley. I basically removed the snout off of it and slipped on the first pulley. I adjusted it to line up with the two grooves on my two two groove harmonic balancer, spaced it out slightly and welded the second groove pulley on the snout to line up with outside groove on the balancer. It works great and looks very acceptable.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | The only one I have seen came off a 60 wagon with dealer installed air,it was another pulley made to go over the existing pulley. It was strange seeing a 6 cylinder 2 door wagon with dealer installed air,the compressor was just as large as one for a caddy and would imagine it bogged down the 235 some. | | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | I have the balancer issue taken care of. I am using a dual groove balancer for a 250. | | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | Thanks for the suggestion. I didn't want to put a lot of work into manufacturing or modifying something and then find out that there is an easy alternative. | | |
