3 members (baldeagle, SWEET, NJC), 43 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
Trying to find Casting number 473483, and stamped number F0102DKB Please help. Thanks in advance.
Could not find it in search.
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
Just a suggestion....if you included a little bit more info on what you DO know about your vehicle/engine, some of the more knowledgeable guys might be able to help. My limited resources show the 6 digit casting numbers as being on some of the older engines. However, there were no 216, 235, 261 Chevy engines with the first number in the 4 series. I use the inliners info as well as:
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/cast
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
More info would be helpful.
I am editing my post because I thought you had an 8 cylinder (DKB is also an 8 cylinder suffix) but now believe you have 1973-79 or 1975-85 250 6 cylinder.
You'll find your casting number on this page if you look hard enough about half way down the page.
http://www.butlers-a1.com/chevym.htm
From the stamped number, I believe the
"F" = Flint production plant
"01" = January
"02" = 2nd day of month
"DKB" = 250 cid with TH350. (according to this nova site, look at the bottom of the page under "1979")
http://novaresource.org/codes.htm
Someone may have better info to share but I think this will get you close to where you need to be.
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Yes it did help. I found the sites and have added them to my Favorites. Thank you so much. That was what i was after. The engine is free and was removed from the vechicle,and with an unknown history. Have a great day.
Slider
