2 members (Thomaslb, Eddie54), 166 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#70856 12/30/2006 2:54 AM
I'm removing the hubs on my '42, 3/4 ton to install some new lug studs and I need to know how to adjust the stock ball bearings-for now.
I wonder if Timken(Or any American manufacturer) makes replacement roller bearings. Anyone know a part # ? cool
#70857 12/30/2006 3:16 AM
This is what the manual says. Not sure about aftermarket bearings for that year truck. http://chevy.tocmp.com/1941shop/41csm079.htm
Bill Burmeister
#70858 12/30/2006 3:42 AM
Thanks, Really good link. I saved the site to my fav's.
Unbelievable how much info is avaliable for these old vehicles.
Guess it just goes to show that these trucks were built for the long haul.
#70859 12/30/2006 8:51 AM
The original part numbers are here
http://chevy.tocmp.com/1929_57chevyparts/57cmpc0533.htm
Metric dimensions can be found here for the 909026 and 909025 numbers. (Work your way through the menu to the front wheel ball bearings page.)
http://www.mbs-m.co.jp/flame.htm
Maybe an auto store can cross reference something from these numbers.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#70860 12/30/2006 6:22 PM
It was interesting to read the service manual description. It was very much the way I was taught to tighten a wheel bearing by an excellent factory trained mechanic. Make sure the bearing is seated, then back off, stopping on the snug side. I never thought about how snugging the bearing would allow for a "wear-in" fit.
One of the things a guy can still do on a vehicle old or new is brakes and this practice has always served me well. Thanks for that link.
#70861 12/31/2006 4:33 AM
Thanks for the #'s. I'll take them to the local chain and bearing shop here. I'll bet they can find something.
#70862 12/31/2006 5:05 AM
Good eye, Randy & Bill.
Thanks for noticing that the following info listed at www.partsamerica.com is not for a ¾ ton.
Front Inner - SKF B52
Front Outer - SKF B67
Here's some additional info, but, like Randy said, make sure it is correct for your application.
FRONT WHEEL ANGULAR CONTACT BALL BEARING & TAPERED ROLLER BEARING
909025(Ball)or 909025R(Tapered)
OEM No. GM 909025 FAFNIR10025
SKF 909025
BCA B-25
Application: GM BUICK(Centurion,Electra,EstateWagon,Invicta,Le Sabre,Park Avenue,Wildcat), Cadillac (Calais,Deville,Eldorado,Fleetwood Brougham,Sedan,Limousine,Commercial Chassis) Truck 1 Ton Chevrolet,Truck 3/4 Ton
909026(Ball) GM 909026
OEM No. GM 909026 FAFNIR10026
SKF 909026
BCA B-26
Application: GM Truck 3/4 Ton Chevrolet
-Tom
1950 Chevy 3100 w/ 1956 235
#70863 12/31/2006 5:51 AM
Check your numbers carefully.
The SKF bearings listed above could be for a 1/2 ton instead of a 3/4 ton.
#70864 12/31/2006 7:34 AM
yeah, those bearing numbers [B52/B67] are for 1/2T for sure
