| | | Forums66 Topics128,204 Posts1,057,292 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Hi,
I'm in need of some help. I'm restoring a 1954 chevy 3100 truck. I removed the front brake drums and found that the hubs are part of the drums. I went to carquest to get new ones drums, no problem, $33.98 the machine said they could NOT remove the old hubs because they did not have the tools to do so anymore. Has anyone run into this problem before? Any advice would be awesome.
Thank you Chevytruckdaddy.
Chevytruckdaddy
| | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | Carquest doesnt have a Hammer and a chisel? Chisel off the 2 or 3 rivet heads on the outer face of the drum. The 2 pieces will then come apart. | | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Ok Awesome, I can grind the rivets off with my grinder. How do I put them back together?
Chevytruckdaddy
Chevytruckdaddy
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Grinding or drilling the heads off will work. They do not need to be re-riveted. Your wheels will hold them in place. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I drilled through mine,then whacked the heads off with a chisel.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Thank you guys for all the help and the advise. I have this project under control. :-)
Chevytruckdaddy
Chevytruckdaddy
| | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Can I ask what drum you ended up going with? Size, bolt pattern etc? I have the exact issue but I cannot find the drum to use for my 5 4 3/4 hub. The drum I had was like 12 inches by 3 inches deep I believe.
Scott M.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | A 3100 would be a 1/2 ton with 6 lug wheels/drums. A 3/4 ton would have 8 lugs and are probably not stocked by most auto parts suppliers. Possibly ebay or post a wanted ad here. Fred
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | scooter M ...maybe a search on the 8 lug drums will show some results. Not long ago I remember someone here had found a really nice substitute but I can't remember who/where. Check the one ton forum or ask a question there. | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Thanks everyone for the suggestions. The drum is a 5 4 3/4 bolt pattern, probably should have mentioned before so that everyone didn't have to waste anytime. I ended up doing a bunch of leg work which seems pretty typical with this old truck, seems like a going theme on this message board in fact. Part of the fun huh? Anyway, it turns out this drum is from a Chevy car, bel air or biscayne to be exact. Around 67-68 per the dimensions of the thing. I am crossing my fingers In hopes that's the one I ordered from summit is the right one. Ready to have some forward progress on this suspension/ front end/brake job.
Scott M.
| | | | | Joined: Mar 2016 Posts: 2 Moderated | | Moderated Joined: Mar 2016 Posts: 2 | I'm also replacing my front drums. Do I need to remove the remaining part of the rivet from the hub? Has anyone experienced any problems with leaving them in? | | |
