0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 61 | I want to remove the heater and replace the 6 volt fan motor. How is it held to the firewall. thanks, Bill
Bill S. Tempe, AZ
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Depends on the type heater you have. If it is a recirculating heater it's bolted to the firewall, accessable from under the hood. If it's a fresh air heater it's bolted to the passenger side kick panel accessable from floor level inside cab. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Depends on the heater you have. if it's the deluxe heater, there are six bolts on the side kick-panel area and two nuts under the hood on the fire wall. | | |
