3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
The new toeboards I recieved from Classic Parts for my 1958 1/2 ton do not include the "reinforcement rings" where the cab mount bolts insert. The old ones are so rusted that they can't be used. This has got to be a common problem - how has it been solved by others?
Thanks!
gobolt
Yeh, I would like to know too. If I can't find a good cab I will have to replace the same on mine. I am sure someone has dealt with this before.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
ttt - still looking for direction if anyone has some. Thnaks!
gobolt
Still looking for advice if anyone has some to spare.....thx
gobolt
I don't have experience with that cab, but I'm wondering if you could just use large body washers under the bolt head where it passes through the floor.
Drew
I'm not sure about the TF series cabs,but my new cab mount kit for my AD came with new 'top hat' style reinforcement washers.
Is this the sort of thing the TFs have?
It recesses the bolt head so there's no bulge in the floor covering/carpet.
More pix on Flickr.
Mine too. That's why I suggested the body washers. I checked Classics web site and the panel they sold for the driver side clearly shows the raised area, so I'm wondering if I don't understand what he's referring to.
Drew
The original and replacement floorboards are recessed where the bolt mounts. The difference is the original recessed area is reinforced with a second layer of metal welded on, form-fitting into the recessed area. Body washers may have to do.
gobolt
Is it possible the second layer you see is an added spacer to help align the body as mounted on your frame?
Drew
appears original/factory to me...
gobolt
