2 members (52Carl, Uncles51), 61 guests, and 1 robot.
Topics128,022
Posts1,055,387
Members48,422
#706529 12/26/2010 11:33 PM
I went to turn off my truck&it wouldnt shut off.I stoppped the engine by covering the choke with my hand.Do I have a bad switch?I have a 58GMC 270engine 6cyl key start.Or do I have a loose wire ??
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
3B Offline
Hy dtwbcs, Happy Boxing Day, without touching the ignition switch, put your meter between ground and the coil power input terminal and see if you still have a circuit. Most likely your switch has decided to retire, if you had a loose wire it probably would have quit when you didn't want it to, hope that helps.
3B #706550 12/27/2010 1:54 AM
THANKS,kinda was thinking the switch finally gave out.Ordered one just in case-
Danny
If you have 12v., and if you have an alterntor, and if the new switch does not do the trick, e-mail me, because I think I know what the problem is.
Don't know if you have an alternator and electronic ignition. A friend of mine had this problem, seems the alternator provides the power to keep it running. He had to install a diode to keep the alternator from feeding back to the ignition system.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
