3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I went to turn off my truck&it wouldnt shut off.I stoppped the engine by covering the choke with my hand.Do I have a bad switch?I have a 58GMC 270engine 6cyl key start.Or do I have a loose wire ??
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dtwbcs, Happy Boxing Day, without touching the ignition switch, put your meter between ground and the coil power input terminal and see if you still have a circuit. Most likely your switch has decided to retire, if you had a loose wire it probably would have quit when you didn't want it to, hope that helps. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | THANKS,kinda was thinking the switch finally gave out.Ordered one just in case-
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | If you have 12v., and if you have an alterntor, and if the new switch does not do the trick, e-mail me, because I think I know what the problem is. | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Don't know if you have an alternator and electronic ignition. A friend of mine had this problem, seems the alternator provides the power to keep it running. He had to install a diode to keep the alternator from feeding back to the ignition system. | | |
