9 members (chevy51truck, Gdads51, Woodcmiami, KEVINSKI, Peggy M, Wickedbass, Tinker5, Hotrod Lincoln, 1 invisible), 101 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#706296 12/25/2010 3:50 PM
Hi folks.First time posting hope everything goes well.
I have a beauty for you guys its a 1954 chevrolet 1700 Canadian made all original. I am a 27 years firefigther veteran from Quebec Canada. I was the last guy to operate this truck in 1998. It was put in storage until 2008 when somebody wanted to made a flat bed truck with it. I told myself over my death body.I since convince our association to restored it. I will try to keep you posted. You can see photos at
http://www.flickr.com/photos/old_betsy/sets/
Lieut DGoss #706301 12/25/2010 4:19 PM
That's a dandy. Doesn't look like it would take a lot to restore it. Glad you saved it. Keep us posted on your progress.
Oh, and welcome to the Bolt!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #706361 12/25/2010 8:06 PM
Moderator
Moderator
2 Offline
Rich
Great looking FireBolt.
You will have a blast with it.
Merry Christmas to you and your family!!
And welcome to the stovebolt Page.
All you have to do here is ask a question, and it will be answered.
2-Ton
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
2-Ton #706364 12/25/2010 8:13 PM
Nice Truck.
Welcome to the site.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Bonjour Lieut DGoss
We are just fooling around with a 1953 fire truck engine as a possible transplant into a military 6x6 Chev C60x Cab 13 Canadian Military Pattern..... our engine is a 248 we were hoping for a 270 cu. inches...... what is the size of your engine?.... and what is tha brass contraption under the carburator.... is it a governer..... and is it powered by the on board water pump demand...?
Thanks for your help...
Bob C.
Hammond, Ontario
...just a slide East of Ottawa
Bob C.
CMP Heaven
The Hammond Barn
RAC1812 #707322 12/30/2010 12:43 PM
Hi Bob
I will mesure the motor for you, (it is big and heavy). On top of the carburator yes it is a governer, it is use to control the water pressure ( When 2 lines or more are used )and also to protect the pump against water hammer. On top of water pump it is a cooler, in case the motor get to hot during long pumping operation( to my knowledge it never been used )I will be glad to answer you question if i can.
Lieut DGoss #707364 12/30/2010 4:14 PM
62401
Bienvenu!
Good to see someone from the Eastern Townships in the Stovebolt Firehouse! I grew up in Georgeville. Beautiful truck, too -- thanks for saving it!
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Lieut DGoss #707692 12/31/2010 6:23 PM
Hi Bob here are the dimensions of my motor.
Overall lenght (including bell housing)= 40" in. W/O bell housing = 33" in.
Width (manifold included) = 16" in.
Bell housing (including motor mounts)= 21" in.
Hope this help.
Any salvagable parts on the firetruck.
P.S. I go halfway up to Ottawa 3 weeks out of 4.
Happy new year.
Dom
Hi John.
We were practicaly neighbours just across the big pound LOL.
My question is what would be the equivalent to my truck in US model.
Happy New Year.
Dominique
Lieut DGoss #707704 12/31/2010 6:43 PM
I've noticed something very interesting, about some of the photos i've seen of Canadien built Chevrolet AD Big bolts. They look to be using Heavier GMC axles on some of the photos. You would never see the Heavier, larger 6 stud wheels on a U.S. built '47-'54 Chevy Big bolt. Does this truck have a GMC 248, 270, or 302 engine, or Chevy 235, or 261 engine. Does it have a SM420 4 spd. tranny, or Heavy Duty Clark 5 spd. tranny, that GMC usually paired, with the Heavy axle trucks.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #707771 12/31/2010 10:56 PM
The engine is a GMC 270 cu. in. and the axel as far as i know is stock from GM,
Now Thibault ( Firetruck mfg ) may have ordered special for them.
The tranny is a 4 speed with a Eaton 2-speed 16,600 rear axel
Lieut DGoss #707943 01/01/2011 5:56 PM
Yes, Your truck is equipped with GMC chassis, & running gear, like all Canadian built Chevrolet "Maple Leafs" were equipped with up until the "Maple Leaf" name was dropped with the 1952 model. Noticed in your photo link that the gvw is 18000lb.'s instead of 16000lb.'s as a U.S. built 2 ton model. I've got literature on a Canadian built 1949 Chevrolet "Maple Leaf" 1700 series 3 ton truck, that is pretty much spec.'d the same as yours. You have the same Clark 5000lb. front axle, & Eaton 16600lb. rear axle, as the GMC 450 series 3 ton COE, I recently sold. A comparable U.S. built '54 Chevrolet 2 ton, would have came only with a 4000lb. front axle, & 13000 lb. Timken rear axle. You have a very unique truck. I like it alot. So according to my info., i'd say it'd be safe to say you have a Heavy Duty 3 ton 1700 series.
Spanky Hardy
1950 GMC 250 1-Ton
Moderated by  69Cuda
