9 members (Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51),
83
Mod | | | Forums66 Topics128,075 Posts1,056,003 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | Has anyone changed out the standard headlamp bulb on your early chev pickup with AutoLoc's Snake Eye Conversion Bulb? I have a Painless wiring harness to handle the additional amp draw but was wondering if you had any problems in installation.
Any info will be appreciated.
Dan | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have the similar Tri Bar headlamps, didn't have any problems at all. I ran mine through the stock style harness and switch, no issues even with the Silverstar H4 bulbs i installed in them.
Bill Burmeister | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Same here. I used TriBar sealed beams on my '40 with Painless wiring harness. Just plugged right in - no issues. | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | I use Hella and Cibie H4 housings in my VW's. They have an excellent beam pattern and cutoff. Your harness should handle a stock 60/55 watt bulb. On my vehicles I do add relays to take the current off the switch and provide maximum power to the lamps. I noticed a difference after adding the relays. For the stock 6 volt guys there are 6 volt bulbs and relays available.
Ted My ride but looking for a Deco Bolt for the wife.
