4 members (frogfarmer, BillCollins, VicZ, oldsteve), 111 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
' Offline
Has anyone changed out the standard headlamp bulb on your early chev pickup with AutoLoc's Snake Eye Conversion Bulb? I have a Painless wiring harness to handle the additional amp draw but was wondering if you had any problems in installation.
Any info will be appreciated.
Dan
I have the similar Tri Bar headlamps, didn't have any problems at all. I ran mine through the stock style harness and switch, no issues even with the Silverstar H4 bulbs i installed in them.
Bill Burmeister
Same here. I used TriBar sealed beams on my '40 with Painless wiring harness. Just plugged right in - no issues.
1940 Chevy KC 1/2-Ton
I use Hella and Cibie H4 housings in my VW's. They have an excellent beam pattern and cutoff.
Your harness should handle a stock 60/55 watt bulb. On my vehicles I do add relays to take the current off the switch and provide maximum power to the lamps. I noticed a difference after adding the relays.
For the stock 6 volt guys there are 6 volt bulbs and relays available.
Ted
My ride but looking for a Deco Bolt for the wife.
