Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (baldeagle, TexasJim50, ndkid275, Gone, RaNfLaS, JW51, Shaffer's1950, Donf, 1 invisible), 41 guests, and 3 robots.
Topics128,005
Posts1,055,253
Members48,418
#70717 12/28/2006 4:17 AM
I recently purchased a 292 that is a Mercury marine engine. Engine is new with less than 5 hours time on it. What is the difference if any between these engines and the truck ones? My son worked a couple of summers at Mercrusier in Stillwater and he said the only difference is in the gaskets. True? Decals on engine indicate 200 hp and 93 octane fuel. Any help would be appreciated.
#70718 12/28/2006 5:09 AM
I've seen this topic come up several times. I did a search here and on Inliners.org and the only thread I came up with is here;
http://www.inliners.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=002239
and it's for a 250 and,,, From the octane requirement sounds like they have changed the compression. Have you checked any of the casting numbers?
Larry
I don't own a vehicle that isn't old enough to drink.
#70719 12/28/2006 5:41 AM
No hands-on knowledge with the sixes, but the Mercruiser V-8's have a tendency to be hot rods, with more compression, hotter cams, and usually bigger carburetors. if they're reccomending 93 octane, I'd guess it's 9.5:1 compression or higher.
#70720 12/28/2006 6:10 PM
checked the casting numbers and here is what I found:
engine block 3921970 66-76 292
head 3927763 67-72 74cc chamber
two other numbers on side of head between spark plugs were 7768 and 5060.
Has Mercruiser alum valve cover. Will be installing engine in a '46 1/2 ton and adding electronic ignition from a later 292. Any one with experience in this model? Have installed a pacer independent front end under the truck. Plan on using a 4 speed since I have a 3:08 rear end.
#70721 12/28/2006 10:39 PM
Riding in the Passing Lane
Sounds like a great installation to me. I,ve worked on hundreds of 292,s. Tough engine. The only weak point is the exhaust manifolds. They burn em out & warp them. I would use headers or maybe the marine version has something better then the trucks.
1972 Chevy c10 Cheyenne Super
#70722 12/28/2006 10:40 PM
some body might have immediate knowledge of this,but one thing we have checked on marine engines is the direction of rotation. it seems that some rotate the opposite of automotive engines. good luck!
our garage is a non-profit organization
#70723 12/29/2006 4:57 PM
Gary, on twin-engine boats, one engine will be counter-rotating, at least most of the time. I think that's mostly the V-8's, though. Lots of 350's and 454's out there like that!
#70724 12/29/2006 8:00 PM
Junior Member
Junior Member
One difference may be the camshaft. On Inliners there have been Mercrusier threads and some say they run great and others say the cams are all wrong for a motor vehicle. It may be worthwhile to degree it to be sure.
