| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I just installed one of these on a 65 GTO with a OPTIMA .Looks very good and fit great.Checking with the company for 6 volt cover. http://www.tartopper.com/ | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | webstershotrods, When you check for price/availability, would you please find out the top dimensions? If the battery terminals come through the holes shown on the top of the 6v topper, that top might not fit on a 6v Optima placed diagonally in an Advance-Design battery tray. http://quailservices.com/index.html The price directly from Tar Topper looks a lot better.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | New Castle Battery which is now Axion Battery Co. is a long time manufacturer of antique battery styles with modern power. Here's their web,Turbostart. http://www.turbostart.com/
Drew
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | The Optima battery will not fit in an Advance-Design battery tray... I measured it for the 54... Turbostart has three 6 volt batteries all for Fords, Ford 2HF, Ford 2LF. Ford Model A ...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have used Optima 6v battery in my 1954 Chevrolet trucks' battery trays, using the original battery hold down. As I posted above, the 6v Optima has to be placed on the diagonal on the original tray.
I also am able to use the 6v Optima in the stock battery tray on my 54/55 6v (positive ground) New Design GMC COE's battery tray.
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I talked with the TARTOPPER company salesperson today.They will not make a 6 volt cover any time soon.There reason was tooling is to expensive and economy also is to bad . I may try to make my own later will post pictures when I get the time to fabricate one.
