1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 9 New Guy | | New Guy Joined: Sep 2010 Posts: 9 | hey all! i have a 36 1/2 t and everything is there... orig drivetrain. ..it has real nice patina going on... no cancer. its in great shape.. i want to use it as a work truck in a sence.. nothing crazy just putting around town... i will drive on the freeway a bit but i dont mind driving 50mph...i am not going to paint it.. just a nice putter...
so my ? is is it worth rebuilding the stock engine.. i think its a 207.block # 836010-9. even though it is a "dipper" how reliable are they for my application.. i would love to re use the engine... just because everything fits..
2nd? what is the discription of my trans.so i can get a rebuild kit for it. its a 4 speed, granny first, with looks like a reverse lock out lever on the shifter, # on drivers side of case 590474,# on the top near shifter is 590511
and last ? what is the gear ration in the rear? 4:10-56
thanks guys and any help would be great
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 |
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | mchotrods, I also have a '36 Chevy pickup that I bought in 1965. I ran it as a rat rod for about 50,000 miles when I first got it with a 283 Chevy, B & M Hydrostick and '60 Chevy pickup rear end with 3.90 gears.
Then in the early 70s I restored it and drove it from Southern California to the 1976 VCCA national meet in Colorado Springs. While there, I also drove it to the top of Pike's Peak, 14,110 feet above sea level. That's the only show I ever took it to because, to me, shows are excruciatingly boring. The trip was great, stopping along the way to camp and fish in the Rocky Mountains and also camping on the deserts of Utah and Nevada.
From that round trip to Colorado and the 35 years of subsequent putting around I learned that a '36 Chevy is a completely reliable vehicle. The stock rear axle ratio is 4.11:1 and even at 50 MPH the engine is pretty revved up and there is a lot of cab noise. I dealt with that problem by putting 3.55 gears from a powerglide equipped '51 Chevy car into a '37 Chevy car rear end. Getting the '37 rear end to fit the '36 pickup required shortening the driveshaft and torque tube about 6 1/2 inches and moving the spring perches inboard 1 7/8 inches, both easily done at home if you have a chop saw and stick/mig/tig welding equipment. The '36 brakes and U-joint fit the '37 rear end so it was a pretty simple conversion. Although a major deviation from "Correct" the conversion would only be noticed by a fanatical purist who has crawled under the truck and noticed the unequal length axle tubes.
If you prefer synchromesh shifting, those trucks also came with a 3-speed transmission.
Ray
Ray
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If aluminum pistons are used to ease load on the rods, these are fine engines.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 9 New Guy | | New Guy Joined: Sep 2010 Posts: 9 | | | |
