4 members (Chip O, Hotrod Lincoln, 1955 1 Series, Barry Martak), 120 guests, and 3 robots.
Topics128,095
Posts1,056,477
Members48,444
#696158 11/18/2010 10:54 PM
I was driving by the local scrap yard and saw this truck. I believe it is a 1935 but it has juice brakes. my 35 chevy truck does not so i am having them cut the front and rearend out. i also took all the emblems one obove the grill that says gmc and the ones on both sides of the engine cover. are these alot rare than the chevy
took the id tag from under the dash
so people are looking at this post any answers
1. did the 1935 gmc trucks have juice brakes
2. can i use them for my 1935 chevy
3. are the gmc emblem, hood badges and the vin or id tag worth anything.
Are you sure its a 35? and not an early part of the year 36? from what I know 36 was the first year of the juice brakes... but they did make the high cab for the first half of the year so maybe they had the juice brakes...
If you look in the doors of a high cab 36 the doors themselfs will be framed in steel unlike the previous 35's and 34's...
Thats my best guess.. sorry for being late to the reply i dont stop by all that frequently... if it were me.. id save the whole truck!
CORPO #704952 12/20/2010 7:33 AM
i have a 35 chev 1 1/2 ton and it had mechanical brakes. we put 36 hydraulic brakes on it. if you can send me photos, i might be able to id. if you have it, send me the vin number.i am in need of a truck frame for mine. i am in michigan and you can contact me at [email protected] i am also looking for a good set of front fenders.jdtow
jim send me a e mail if you need a frame i am in MI also [email protected] Glen
According to "GMC Heavy Duty Trucks 1927-1987" by James K. Wagner, Lockheed hydraulic brake replaced mechanical brakes on all models through 5 tons for 1935.
I have 2 35s both high cab duely one short bed with front mec. and rear hyd the long bed has all mec. the don't have any ID tags on them so I think you may just found a late 35 early 36 both of mine have all wood door frames check your door frames
patmore I forgot to ask did you see the cowl on that truck i'm looking for both lower 8 inches of cowl for mine if you can put me in contact with the yard by phone/name /e mail I would be thankful by the way you said you took emblems off of the side hood don't think 35s had them could be wrong my 35 has slats on the side that go up and down
