| | | Forums66 Topics128,180 Posts1,057,146 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Fellas, here is what I'm pondering:
I found a good, fully functional 261 from a 57 Pontiac, 20 minutes from my shop. Complete from bellhousing to air cleaner for 400$CDN (325$US).
The 235 in my 53 is NOT the original motor, it's a non-pressurized oiling system, babbitt engine. It 'sounds' tired...
I'd like to eventually add an Offy twin carb intake and Fenton (or split) exhaust, maybe a mild cam? Just for the heck of it, for looks and sound...
I'll also be switching to a T5 trans and Blazer rear end.
I guess what I'm asking is: am I mistaking or does it sound like an easy, worthwhile swap???
I need some validation, fellas! | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I'd jump on it if I were you. These old engines seem to be getting hard to find these days.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#7054 01/31/2005 11:13 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The 261 should drop right in. There should be some info in the tech tips, in an archive search, or in the technical section at www.oldchevytrucks.org . | | |
#7055 01/31/2005 11:50 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Must be a Canadian model. I,ve never heard of a 6 cyl. 57 pont. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#7056 02/01/2005 12:03 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Before you hand over the cash, get the casting numbers off the block and check it out on the inliners site.
Gord 1954 1/2 ton 235 4 speed
#7057 02/01/2005 12:44 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Whizzer,
GO FOR IT....sounds like a good deal if it is a 261 for sure. Since you are doing the T-5 and rear, why not go big and do it all at once. You can spruce up all the stuff you are going to install. When it is all ready to go, put it in and be back on the road sooner. | | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Wrench, yes, it is a Canadian model.
46, that is the plan! Offy, Fentons, T-5, etc...
I'm going to take my time, even if it takes me a year. I want to make it right, with the right stuff...
I just cant help myself, I cant leave it alone. I love the go-fast goodies and like the idea of a 'sleeper': stock exterior with faded paint, scratches and dings and eye popping engine bay, nice and shiny with a healthy motor rumbling... :p | | | | | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | The 261 full pressure oiling will indeed fit the motor mounts etc. Your water pump will need to be adapted with the short shaft to clear the radiator, however this will make the original fan interfere with the lower supports. You can get an adapter to use an different water pump which requires an extra hole be drilled in the block or you can put a pusher fan in front of the radiator and eliminate the fan. If you are going to add dual fenton exhaust, you will have to bring the oil filter lines out past the hot manifold with metal lines and adapt them to a remote filter. If you have the filter from the 261 with the large cannister for the PF 141 filter the housing may be cast aluminum and able to be polished. It will conveniently fit above the steering column on the firewall. One of the past posting also suggest that you change over the clutch to the larger size (10.5 inch ?) to accomodate the extra torque of the 261.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
| | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | Whizzerick,
At that price, I say go for it. I paid $275.00 for a '54 261 that was in dire need of a rebuild. Nonetheless, after the rebuild I am very happy with the results.
Since '57 261 you are considering came from a car and most likely has a fiber cam shaft gear, you may want consider replacing the timing gears with a new gear set containing an aluminum cam gear. The aluminum gear will make more noise; however, it much more durable that its fiber counterpart.
Good Luck. I am glad to hear of your find. | | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Great info fellas!
- Will I be able to use the clutch from my 235 (wich I believe should be 10,5) ? | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I replaced my 235 with a '61 261 and really like it. I used an 848 head from a 235 so holes were drilled in it to match the extra water holes of the 261 block. I stayed 6 volt so had to drill new holes in my old generator bracket to match the mounting holes on the block. All in all, a pretty easy swap. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jun 2004 Posts: 40 Junior Member | | Junior Member Joined: Jun 2004 Posts: 40 | I just got my conversion running. (46 chevy 3/4 ton) 261 t5 tranny (from firebird with a chevy tail. No problems with the clutch, slipped right in without grinding the input shaft, had the higher spline count)
4.10 rear end
changed intake manifold to one from jim carter that fits a holly carb,
hei ignition fenton headers to fit the intake better. fired up with less than 2 cranks. a bit loud going to the muffler shop but boyu was it fun.
Would do it again in a heart beat.
Ted Wilson
| | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Ted, what is that 4.10 rear end out off? What are you getting, MPG and MPH-wise with that setup? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A 261 is a pretty easy drop-in for a 235. You may or may not find the throttle pivot in the same location, though. The external dimensions of the block, crankshaft, bellhousing, flywheel, starter, manifolds, water pump, distributor, fuel pump, and covers are all the same.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I just cant help myself, I cant leave it alone. I'm glad the only cure for this disease is more of it! | | |
