1 members (baldeagle),
93
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70636 12/27/2006 2:27 AM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | Although I did take note of where the old ring gear was placed on the differential carrier before I removed it, would that matter if I was installing a new 3.55 ring gear? Can you install the gear in any position, or does the bolt pattern only allow one position? | | |
#70637 12/27/2006 3:31 AM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Any orientation is ok but be sure to use guide pins(bolts with no head)and seat it evenly. It should be snug on the carrier.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#70638 12/28/2006 5:12 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You should set the bearing preload after installing a new gear to make sure it wears evenly.
