5 members (Gdads51, Bill Hanlon, klhansen, Millenimech, Otto Skorzeny), 51 guests, and 2 robots.
Topics128,036
Posts1,055,454
Members48,422
#70636 12/27/2006 2:27 AM
Although I did take note of where the old ring gear was placed on the differential carrier before I removed it, would that matter if I was installing a new 3.55 ring gear? Can you install the gear in any position, or does the bolt pattern only allow one position?
#70637 12/27/2006 3:31 AM
Any orientation is ok but be sure to use guide pins(bolts with no head)and seat it evenly. It should be snug on the carrier.
You Tube
#70638 12/28/2006 5:12 AM
You should set the bearing preload after installing a new gear to make sure it wears evenly.
Paint & Body Shop moderator
