10 members (Gdads51, Forty9, TexasJim50, TooMany2count, 55shaker, Guitplayer, Otto Skorzeny, Peggy M, Bill Hanlon, cmayna),
145
Mod | | | Forums66 Topics128,259 Posts1,058,292 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70616 12/26/2006 10:46 PM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Hey Folks,
Hope you all had a good Christmas. I've got a dilemma. I need the bellhousing off a seized 216. Problem is I can't remove the pressure plate because I cannot rotate it to get to the bolts. Has anyone else encountered this? Did you find a way to take the bolts out?
Colin | | |
#70617 12/27/2006 1:21 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | This was an easy dilemma. I had forgotten that a few months ago I filled it full is diesel. A little prying and she turned over alright. But since its a 'make work' project that shouldn't bother me :rolleyes: :p . So I got the pressure plate off.
If anyone still has the answer i'd be interested to hear it.
Thanks. | | |
#70618 12/27/2006 1:33 AM | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Colin, could you possibly turn the engine upside down remove the oil pan and disconnect your connecting rods, and your main bearings, and then the cam, and front block plate now you should be able to lift the crank out. Oops the engines half apart now isn't it, hope that helps. | | |
#70619 12/27/2006 2:25 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I got the engine to turn over so I got the pressure plate of 3B. Thanks anyways.
Thats lots of work, but I guess if thats what had to be done it would work.
Thanks | | |
#70620 12/27/2006 11:33 PM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I'm having the same problem... I can't rotate it to get the bolts off of my 52... the engine won't turn.. I took the spark plugs out yesterday.. I'm going to pour a little oil in each cylinder and try turning it each day to see if it helps...
1952 Chevy 5 Window Restoration
#70621 12/28/2006 1:43 AM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I've put oil in each cylinder.. I'll try turning it each day and see what I can do with it!
#70622 12/28/2006 6:06 AM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Thats what I had to do to mine 3B... | | |
#70623 12/28/2006 8:55 AM | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Looks like you could pull the transmission to gain access to the pressure plate without turning it over. | | |
#70624 12/28/2006 4:02 PM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | well the transmission is off but I can't turn the pressure plate to get to the bolts.. and someone correct me if I'm wrong, but don't you have to remove the clutch/pressure plate/flywheel before I can get to the last 2 bolts on the bellhousing?
#70625 12/28/2006 9:19 PM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Your right Blake, all three of those things have to be off. To loosen up your engine, pry through the starter opening at teh flywheel teeth a little back and forth. I also jammed a 2 foot screwdriver between the teeth on the harmonic balancer and worked that back and forth.
Good Luck.
Oh, and after you remove those things there will be four bolts. | | |
#70626 12/28/2006 9:51 PM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | Thanks Colin..
I tried it this morning and it wasn't budging at all but I'm going to keep working it and see if it loosens up..
#70627 12/28/2006 9:51 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I just got doing this. Blake, you are right. There are bolts that are holding on the bell housing that are under the flywheel. You will need to take off the pressure plate, clutch plate, and the flywheel to get to them.
To get to the pressure plate bolts that are up on the top behind the bell housing you will need to use sockets, then knuckles (socket extension knuckles), before your extension and wrench. You may need to pull the transmission (I think you said you have done this) and the shifting fork to get to the bolts but it can be done. You will need to go through this shifting fork hole to get to one bolt.
Then you can get the flywheel bolts off. When the flywheel is off you will see the top bolts.
You shouldn't have much of a problem. Just take it easy or you will loose skin off your knuckles.
Have fun.
Dennis -there is nothing stronger than the heart of a volunteer-
#70628 12/28/2006 10:33 PM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | i had this trouble once and found that we could move the stuck engine by raising the left rear wheel and turning it back and forth, with the tranny in high gear. we needed to bump it hard in either direction, but eventually the motor turned enough to loosen all the clutch bolts. rocking the vehicle back and forth on the ground with the tranny in high gear might work also if you got some help and enough space.a little oil in the pistons with the plugs out will help this ,depending on what way the engine is stuck. good luck.
our garage is a non-profit organization
#70629 12/28/2006 11:23 PM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | FINALLY!!!! I was able to stick a big screwdriver in the hole where the starter was and turn the pressure plate (took 2 hours to turn it) but I finally got all the bolts off.. now the flywheel and pressure plate are off... That leaves the clutch and bellhousing.. thank God!
#70630 12/28/2006 11:34 PM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | Originally posted by Blake: FINALLY!!!! I was able to stick a big screwdriver in the hole where the starter was and turn the pressure plate (took 2 hours to turn it) but I finally got all the bolts off.. now the flywheel and pressure plate are off... That leaves the bellhousing.. thank God!
#70631 12/29/2006 12:11 AM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I screwed up my last 2 postings ugh...
I've removed the CLUTCH DISC and PRESSURE PLATE... now I have to remove the flywheel... how do I get that off? there are little pieces of metal folded on the edges of the bolts... and then there are 6 bolts...
Do I bend the bent pieces back a little and use a 6 point socket to remove these bolts?
#70632 12/29/2006 1:48 AM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | Mission Accomplished! Thanks everyone for your help!
#70633 12/29/2006 10:56 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My neighbor didn't wanna wait to get the engine freed up,so he used his plasma-cutter and cut a hole for access to each pressure plate bolt. Speed | | |
#70634 12/29/2006 9:46 PM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Good to hear Blake!
Speed, sounds like your neighbour is a real patient mechanic. | | |
#70635 01/01/2007 3:56 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Yeah-he's a riot;if he can't find the right size bolts,he just welds the part on... speed | | |
