| | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | As part of the restoration of my '41 pickup, I'll be removing the dash for clean up and painting. I'll need to remove the choke and throttle knobs to get the dash out, but they appear brittle and potentially easily broken. How do the knobs come off? Do they simply unscrew from the cables or are they molded on, requiring the removal of the whole cable? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You'll probably have to remove the whole cable. If the '41s are like my '38 the knobs are molded to a shaft that then has a wire crimped into the end. The wire & shaft are then inserted into the cable. The whole cable is easy to remove, just unscrew the nut on the back side of the dash.
| | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | If you need new ones try THE FILLING STATION they have knobs or knobs and cabels together / on line catalog | | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | Thanks. I did as Tiny suggested and it turned out to be an easy task to remove the knobs and cables without any problems. | | |
