| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I need to remove the horn button on my '64 to determine what's wrong with my turn signal cancel but I can't find anything in the manual about how to remove it. I don't want to start prying on it and break something. Any advice will be appreciated. thanks.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Don't know about '64, but on my '65 it just pulls off...some rubber holds it on, I think.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Thanks, that's probably it. I tried twisting it off but nothing happened.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There is a rubber surround on the back of the stock horn button on the '60-'66 Chevy/GMC standard steering wheels, which secures it on the wheel cup, via a "friction-fit". It can simply be pulled off, without damage to the rubber ring, horn button or wheel cup. When installing, a little WD-40 or dielectric grease will ease the process of replacing it or removing it in the future. | | | | | Joined: Dec 2010 Posts: 1 New Guy | | New Guy Joined: Dec 2010 Posts: 1 | I am looking for a good diagram of whow the horn button and the turn light cam is put together, especially the 2 springs and 2 keepers in the turn light cam mechanism on my 62 chevy C20. | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | I have a scan of that I can e mail to u . I need your email address
Ken | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Ken, Can you also send the scan to me. I have had this question in my case as well. Thanks for assist. [email protected] | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Hey Ken - Me too please? [email protected]Thank you an Happy Holidays!
Thom Masterson
| | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | I sent it out for you guys Sunday.2:53 pm | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | sorry ken. Just noticed my typo in the email address. If it is not too much to ask.... and I thank you in advance if you would send along the the graphic to my corrected address. [email protected]My column inner workings remains a mystery to me. Hambone | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I did not receive it. The email address is kind of long. Again it's [email protected]Thanks again and Happy Holidays!
Thom Masterson
| | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | I thought you spelled it weird. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Ken, If you are still there. It appears I can no longer find the exploded view of the steering column. Lost in my old computer I think. Can you send it long again. ( [email protected]) Can anyone help me with continuity check of horn wiring. Horn works when shorted directly to battery. Installed all bits and pieces in steering wheel cap. But no horn. Tried shorting (but my method may have been incorrect) horn plate/cap with steering wheel off. No result. I have a great horn and an additional H/L set to play with, but can't seem to figure it out. HB | | |
