0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70514 12/24/2006 7:02 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | :o I just re-read the post and this time saw that it's for a 6400 truck. Being an open driveline,the same concept applies,but it's a lot easier. All you need to do is chock the right wheel,jack up and block the left rear wheel,leave the truck in neutral and mark the driveline,the inside of the tire and the brake backing plate. Now,turn the driveline and count the number of revolutions the driveline makes for a full revolution of the tire. That's your gear ratio. Speed | | |
#70515 12/24/2006 9:08 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Actually, speed, you have to count the driveshaft revolutions of two turns of the wheel to get the ratio because of the differential gear operation, or you have to multiply the driveshaft revolutions by two with one revolution of the wheel. | | |
#70516 12/24/2006 9:22 PM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | :o you're right,Baldy-thanks for correcting me! You can tell it's been a while since I've had to worry about axle ratio. :rolleyes: Speed | | |
#70517 12/25/2006 12:11 AM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Try again, guys! The differential gearing doubles wheel speed, if only one wheel is turning. The gear ratio needs to be figured with 1/2 turn of a rear wheel, if you've only got one wheel free to turn. That's why it's so easy to overheat a tire if it's spinning on a slick spot. 30 MPH on the speedo, for instance, is 60 at the wheel that's spinning. Jerry
#70518 12/25/2006 1:55 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Jerry,
Doubling the speed means more turning of the wheel for each driveshaft revolution, not less. So for a wheel to turn twice as fast, it must travel twice as far, or two revolutions. | | |
#70519 12/25/2006 4:21 AM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | OOPS! Ya got me there! Jerry
